no crank & no fuel
Old Jan 4, 2014 | 07:21 PM
Vicious's Avatar
Car: 89 firebird rs
Engine: 2.8
no crank & no fuel
"Two" problems with my car. 2.8, 89bird
Car didn't crank so i jumped the neutral safety switch and it magically cranked.
Does the NSS affect the fuel pump? should i get that first before messing with the fuel pump?
With the NSS jumped:
My fuel pump doesnt turn on. i dont get fuel to the Schrader valve, i am getting power to the wiring connector by the tank though. so i am thinking of dropping the tank tomorrow and checking out the wiring inside the tank.
it has so far:
new fuel pump, new fuel injectors, battery is good, grounds are good, VATS is disabled in the prom also the relay is jumped correctly, other relays are good, starter is good, alternator is good. pretty much everything lol
Any advice that i can used to turn this sucker on!
Old Jan 4, 2014 | 08:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: no crank & no fuel
The nss doesn't have anything to do with the fuel pump. When the key turns on the ecm sends out 12v for 2 seconds on pin A1 on the 1227302 ecm . Start there first, does the check engine light come on when the key is turned in the accessory position ?
Old Jan 7, 2014 | 09:10 PM
Vicious's Avatar
Car: 89 firebird rs
Engine: 2.8
ohh im sorry i forgot to check that!! just been busy changing the fuel pump lol & cleaning the tank... now i get fuel to the rail but the car hesitates and it almost wanted to turn on. i also sprayed a bit of starter fluid and it almost turned on too...i have spark on all wires...
i also forgot to mention before i jumped the NSS, the crank fuse under the dashboard had no power. i have not checked it with the jumped nss though
Old Jan 8, 2014 | 04:55 AM
Engine: Lb9
Transmission: M20
It sounds like the injectors are stuck from sitting in bad fuel for awhile. You might need to pull them and have them cleaned and flow tested.
Old Jan 8, 2014 | 06:08 PM
Vicious's Avatar
Car: 89 firebird rs
Engine: 2.8
i checked to see if the engine light came on with the jumped NSS and it doesnt come on. Or did you mean with the regular wiring in place?
Old Jan 8, 2014 | 07:27 PM
Engine: Lb9
Transmission: M20
If the fuel pump primes when you turn the key to the accessory position and the check engine light is on . That indicates the ecm is powered up. The only other test I can think of is a noid light. if the light blinks while cranking and you have at least 38psi of fuel pressure the injectors need to be serviced.
Old Jan 8, 2014 | 07:46 PM
Vicious's Avatar
Car: 89 firebird rs
Engine: 2.8
i think ill pull out the fuel rail tomorrow and see if the injectors spray when i crank the engine! thx for the help
Old Jan 9, 2014 | 10:54 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The only time the CRANK fuse ever gets power is when the key is turned all the way to START. ( it's on the same circuit as the starter soleniod wire )
Old Jan 13, 2014 | 06:22 PM
Vicious's Avatar
Car: 89 firebird rs
Engine: 2.8
with the NSS connected:
-the check engine stays on
i did check the the fuel injectors they werent clogged but they arent spraying i dont think theres power going to the injectors
Caspar
Jun 19, 2016 11:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
