Mounting ECU
Old Jan 11, 2014 | 11:28 AM
Tri458's Avatar
Mounting ECU
I do not have the plastic casing/ mount for my EcU. Can I mount it using the original threaded holes but with metal brackets instead, or was it mounted in plastic to avoid the body of the ECU from earthing?
Old Jan 13, 2014 | 05:10 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
What Are You Doing Dave . . . . . ?
Yes and yes, altho I would recommend picking up a plastic housing at your local Radio Hut.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Jan 14, 2014 | 03:22 PM
Tri458's Avatar
Re: What Are You Doing Dave . . . . . ?
Sorry.. I'm confused by your answer, Nina... I can mount it using the original holes and metal mounting brackets?
Old Jan 14, 2014 | 04:54 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Mounting ECU
Do NOT use metal brackets to mount the ECM. The ECM itself needs to be isolated from the chassis to avoid ground loops and help shield against radiated noise.
Either use plastic, or find an original plastic hanger.
Old Jan 14, 2014 | 06:15 PM
Tri458's Avatar
Re: Mounting ECU
As I suspected, Six Shooter. Many thanks.. I will mount inside the glove box instead... I love this forum. I've had some great advice since joining. Thank you.
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
FormulasOnly
Sep 6, 2015 10:42 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
