question about vats...
Old Mar 10, 2014 | 04:56 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
i have a 1991 Camaro with a 305 tbi sometimes it will start fine an others u go out an nothing...so I figured its the typical vats problem....so my question is how do u bypass it? I have read about getting the resistance off the key an making a resistor an cutting the 2 white wires under the dash on the column an soldering the resistor there at the proper plug....my other question is don't u have to bypass the starter also for the vats to be completely bypassed? or am I wrong?
Old Mar 10, 2014 | 05:17 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Re: question about vats...
isn't there something in the driverside kick panel I have to bypass also? if im wrong correct me...I want to bypass vats I hate being out somewhere an the car not start
Old Mar 10, 2014 | 05:40 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Yes. There are two wires... Maybe yellow and green. Take the wiring harness out and connect the wires. My 89 was doing the same thing. No issues now.
Old Mar 10, 2014 | 09:18 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
connect what wires? ive read that u gotta ground a wire or something? or if I gotta cut wires an connect them back which ones are they? or if I gotta ground them which ones are they?
Old Mar 11, 2014 | 01:10 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/tech...formation.html
Do a search , 1001 VATS threads on here
Read
https://www.thirdgen.org/vats_passkey_system
If you do the resistor trick you don't need to touch the relay assuming it is working correctly.
All the resistor does is " fool " the VATS module into thinking you are using the correct key , you are only " bypassing" the key being read
If you have VATS module , wiring or enable relay problems then the resistor will do zilch
Old Mar 11, 2014 | 07:14 AM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
ok so just do the resistor trick then?
Old Mar 11, 2014 | 08:28 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
My problem wasn't with the resistor in the key. It was working fine so "fooling" the VATS with a resistor would have been futile for me. My relay was bad.
I don't think you need to ground anything. The is a green wire going in and a yellow wire going in. Cut them and connect them. Now the VATS system doesn't do anything. I'm not 100% on the colors.
Old Mar 12, 2014 | 02:14 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
u talkin bout the starter enable relay in the kick panel?
Old Mar 12, 2014 | 02:54 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Maybe. Lol. I didn't remove it. My tuner did.
Old Mar 12, 2014 | 04:59 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/elec...ble-relay.html
Old Mar 12, 2014 | 05:04 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As I noted above
Need to specify only in your case ; because the tuner has deleted VATS on the tune
Vats also takes out the injectors so if you have VATS fault bypassing the enable relay will allow the engine to crank but not fire up
Old Mar 13, 2014 | 08:59 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
I have done the resistor trick under the dash...someone had already done it but the resistor was too high for it....but now since ive put the one I made into it its been workin fine so far....
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
