Help with Neutral Safety Switch?
Old Mar 18, 2014 | 04:28 PM
Azshios84's Avatar
Car: 1985 Camaro
Engine: 355 sbc
Axle/Gears: Moser Rear with 4.11
Just the other day my car started to refuse to start in park, but I was able to start it in neutral. Now today its not even starting in neutral. What Ive seen from doing some research its more than likely the neutral safety switch. The other things I have read is that the shifter isnt calibrated for the NSS, or the ignition clip inside the steering column. But I dont know how to approach this fix. Is there anyway to test this without tearing apart the shifter/steering column? Plus I dont want to do the NSS bypass like some people have been doing. I just dont feel comfortable with that, plus dont like the realibility/safety issues that can arise with that. Any help is greatly appreciated!
Old Mar 19, 2014 | 08:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Help with Neutral Safety Switch?
Simple.
Temp jumper the NSS and see if it starts ; if it does NSS is the problem.
If it doesn't the Ign switch is suspect
The Ign switch is at base of column
Need to check for 12
http://92b4crs.tripod.com/86wiring/dia-pics/30-4.jpg
Old Mar 19, 2014 | 08:31 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Simple.
It may be faulty or just out of adjustment
If it doesn't start the Ign switch is suspect.Use a DVM to see if you have 12V at the NSS when the key in START position
See
https://www.thirdgen.org/forums/post...71-post19.html
Need to check for 12V on the yellow wire to the NSS when the key in START position
See
MM2Robinson
Oct 1, 2017 09:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Randomtask2
Sep 10, 2015 08:37 AM
Fronzizzle
Sep 8, 2015 12:10 PM
