No VATS Light at all
Old May 6, 2014 | 06:22 PM
AussieGTA's Avatar
Car: Trans Am GTA
Engine: 350TPI
Transmission: T700R4
Axle/Gears: 3.45
OK guys, another VATS issue, but I'm guessing from my searches this one is out of the norm. Turn the ignition to ON and the VATS light does not come on at all, even the 3 sec test, I also have code 46, and surprise surprise the car won't start.
Both 12 volt voltages at the module are there and the earths check out.
Ideas, other than a VATS module.
Old May 6, 2014 | 10:22 PM
AussieGTA's Avatar
Car: Trans Am GTA
Engine: 350TPI
Axle/Gears: 3.45
Re: No VATS Light at all
It was the key circuit. If its not closed (Ignition lock stuffed) you get no "Security" light at all, and obviously the car won't start.
Old May 7, 2014 | 06:10 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Usually is.
Measure your key pellet resistance , go to Jaycar and buy some resistors and do the VATS bypass
https://www.thirdgen.org/vats_passkey_system
plenty of " how to " posts on here
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
fasteddi
Sep 10, 2015 09:32 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
andy74
Sep 3, 2015 08:41 AM
