Speedometer is a dirty dirty...
Old May 26, 2014 | 05:53 AM
direngrey's Avatar
I have a 1987 v6 firebird with 700r4. and it has an electric speedometer. I have checked my vss up to the 4 out buffer and the purple/yellow have continuity and put out ac voltage (I even tried a new vss. From the box all the dash wiring is connected correct in the dash. I'm thinking either the box or speedo is dead. Is there any tests I can do
Old May 30, 2014 | 02:53 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Speedometer is a dirty dirty...
Use a multimeter to test continuity from VSS to buffer box then buffer box to speedo
Next check that the cluster has power and ground on the proper pins
If those check out, then a bad part is somewhere in the system
Usually, multiple gauges/lights will be inop when power/grd is off on the cluster, but not always. There are multiple pins for each at the cluster
Old Jun 9, 2014 | 07:33 PM
direngrey's Avatar
For everyone whos electric speedos arnt working if you Bridge brown ecu wire with green/blk speedo wire at the buffer box. That's what mine needed. I couldn't find any info on here in my searches.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
