Pulled a Diagnostics Code, Now What?
Old Aug 7, 2014 | 06:43 PM
1986 T/A's Avatar
Car: 1986 Trans Am
Engine: 305 4bbl
Transmission: 5 Speed
Hey All. So in the past week or two i have noticed my check engine light would come on after the car has been on and running for awhile. So i came home today and did the paper clip trick a few times to determine what the problem was. After a few rounds the final consensus is code 53. According to the official thread i found on here it is "High voltage at battery OR High voltage at exhaust gas recirculation valve OR Voltage reference error OR Problem at vehicle anti-theft system" Any idea of how to fix this? Where should i look first? The Car does not have VATS, so i know it cant be that one.
Any advice is welcome, and thanks in advance!
Old Aug 7, 2014 | 07:35 PM
1986 T/A's Avatar
Car: 1986 Trans Am
Engine: 305 4bbl
Re: Pulled a Diagnostics Code, Now What?
BUMP, this car is a daily driver for a guy in Highschool, so i would like to handle it soon.
Old Aug 8, 2014 | 11:16 AM
1986 T/A's Avatar
Car: 1986 Trans Am
Engine: 305 4bbl
BUMP
Old Aug 8, 2014 | 07:01 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
From the FSM:
Code 53: System Over Voltage
  • Code 53 will set if voltage at ECM terminal B2 is greater than 17.1 volts for 2 seconds.
  • Check and repair charging system.
I would strongly suggest you have the charging system checked before you start throwing parts at it.
Edit: Don't drive it like this for too long. If the alternator is constantly putting out that kind of voltage it'll cook the battery.
Old Aug 8, 2014 | 07:57 PM
1986 T/A's Avatar
Car: 1986 Trans Am
Engine: 305 4bbl
Okay, I will look at it tomorrow. The battery and alternator are relatively new, so I might have my good friend at AutoZone look at it.
Old Aug 9, 2014 | 06:33 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
I had a new alternator from oreillys auto parts that was bad(over charging). Have them test it and also see where the gauge sits at.
Old Aug 9, 2014 | 07:05 PM
1986 T/A's Avatar
Car: 1986 Trans Am
Engine: 305 4bbl
Okay, so today I went to Autozone and had them test everything. The battery and alternator are working fine and in proper order, so back to square one i suppose.
Old Aug 9, 2014 | 10:01 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Does the SES light come on and stay on or is it intermittent?
Old Aug 9, 2014 | 10:09 PM
1986 T/A's Avatar
Car: 1986 Trans Am
Engine: 305 4bbl
It'll come on for about 10-20 mins than turn off.
specialized
Jun 18, 2022 09:26 AM
GTAman
Mar 15, 2019 11:40 AM
chazman
Aug 28, 2018 03:25 PM
86IROC112
Aug 31, 2015 07:00 AM
chazman
Aug 22, 2015 02:01 PM
