fb dash into s/c
Old Aug 7, 2014 | 07:06 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
fb dash into s/c
done a v8 swap into a v6.donar car 84 fire bird recipent 85 camaro sport coupe.The oil pressure gauge is a no work and the bird had a tac i'd like to have work.I dont want aftermarket stuff.will the 84 f/b harness work in my 85 s/c and find a v8 camaro cluster?
Old Aug 7, 2014 | 08:24 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: fb dash into s/c
You should be able to swap just the tachometers which includes the oil gauge. Then if the oil pressure sensor still doesn't work you'll need to get a sensor for the new gauge. (Ie. Camaro of that year specific for a gauge and not an idiot light.)
Edit: There is a guy on here that repairs and sells them that might be able to help. If you can't find him I'll try to remember to post a link the next time I see him.
Old Aug 8, 2014 | 09:49 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I still have the conpleat dash with gauges out of the base firebird.of course they are made differently.I was wondering if the pig tails and pin outs on the bird harness and s/c are made the same.I know the conector coming from the engine to the dash harness had more wires.figure one was the tach.that being said I can do without that.I will see if I can change out just the oil gauge.If not I might as well just pick up a set that has what I need.the one in the bird dash was with this motor so its the right type.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
