89 Iroc 350 auto won't start
Old Aug 9, 2014 | 07:19 PM
Napalm's Avatar
To start off in the sequence of events. This car is not driven very much. I started it and pulled it out of the garage and let it run for about 10-15 minutes. I then proceeded to pull it back into the garage and turned it off. The next week i went to do the same thing and the car turned over but would not start. As i am on the ignition next thing you know i see smoke coming from under the hood. I pop the hood and get out to check and find that a ground from the battery to the apron is melted. I replaced the ground thinking that maybe there was a loose connection. I tried to start again and the same thing happened so i eliminated the ground. Next thing you know i still have a no start and i start checking things. I found that i have no spark. I proceeded to replace the coil and the ignition control module. Now i have a week spark but still a no start. What should i do or check at this point. I have checked the other grounds and they seem okay.
Frozer!!!
Jan 19, 2024 04:55 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
wruiz
Aug 13, 2015 09:07 PM
mustangman65_79
Aug 11, 2015 03:17 PM
