whats this wire for
Old Aug 14, 2014 | 05:01 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
whats this wire for
Hey everyone been pokin around my car found a cut and taped off wire in my wireharness.. Not sure what it is for any help be greatly appreciated...
Also i have only high speed on the heater blower.. Car is 89 rs v6.
Old Aug 14, 2014 | 05:08 PM
Joe Tag's Avatar
Re: whats this wire for
My telepathy has been on the fritz lately. How about a picture or at very least a description of where it is and color.
Old Aug 14, 2014 | 05:42 PM
Joe Tag's Avatar
Should connect to a blower relay to get the fan into high speed. You are either running in the lower speeds or it is wired without a relay. I see some other interesting wiring going on there.
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Well there is a pic but... The wire is located in the harness around the pass valve cover ..right around the y in the harness
Old Aug 14, 2014 | 05:47 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Last guy that had the car. Wired a bunch of stuff in.. It has a push start. Key is hooked up but starter wont run when key is turned. Brake light comes on when ya turn the key.. I am slowly figuring it all out.. Car has had the motor replaced in it so im not sure what all has happened... All i get when i turn the blower on is high speed nothing on the other settings.. .. Everytime i dig in to something i find a "trailer park fix" somewhere...
Thank u for the help though
Old Aug 14, 2014 | 06:27 PM
Joe Tag's Avatar
Sorry Dutch, my computer overheated in the middle of posting a diagram to help you. I looked for a place to put an air dam on it but...
Anywho, hope you can understand it. You will need to look at the top right section of the diagram.
Old Aug 14, 2014 | 06:38 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Thank u very much joe tag
Old Aug 14, 2014 | 06:41 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
So it has to be that red one.. "hot all the time" ..
Maybe thats why i only have hi and no other speed for the blower?
Old Aug 14, 2014 | 06:43 PM
Joe Tag's Avatar
Come to think of it, you had the bad ignition switch earlier this week. I'd bet the two are related. If you are running the fan through the ignition circuit with no relay, it will go out again soon.
Old Aug 14, 2014 | 07:00 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Nope ignition switch not me.. My car starts and runs ok.. Need to clean throttle body.. Did iac and put a new egr vac assembly on.. Iac was pretty bad so i can imagine the rest will look the same.. My car just has a crap load of stuff wired to switches in the car for some reason.. Kinda makes ya think buddy watched to much fast and furious. For all the switches i have seen and found lol
Old Aug 14, 2014 | 07:03 PM
Joe Tag's Avatar
LOL was another dutch (920) my bad
https://www.thirdgen.org/forums/elec...-gremlins.html
Old Aug 14, 2014 | 07:08 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Np bro thank u for ur help i will update on what i find... Also still have to update another post i have done lol
Old Aug 14, 2014 | 07:17 PM
Joe Tag's Avatar
YW You're gonna have to tear into that harness and find the orange(probably connected straight to the fan) Black wire comes from the missing relay and is screwed to the inner fender. Purple comes from the relay to the resistor(on air box with the plug in your pic) then goes to the fan. The red wire you need to test for 12v+ the fusible link may be bad at the starter. Good luck.
Edit: on top of all of this you will probably find the resistor is bad if you are getting no lower speeds. Take it out and see if it is burnt in two on the coils.
Old Aug 14, 2014 | 07:35 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
So could bad fuseable at the starter also be the reason i have no start when i turn the key? Right now it wired up with a start button.
Old Aug 14, 2014 | 07:54 PM
Joe Tag's Avatar
Anybody's guess right now looking at the wiring and your description, but there are three down there and they supply voltage to the whole fuse block. Test for 12v past the plastic connector on all of them. You can stick a needle through the insulation and use a test light or volt meter on it. Careful not to ground it out.
Old Jan 5, 2015 | 07:51 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
red wire is live all the time, so im at a loss, the p o did alot of cut and splice.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
