cut out sw.
Old Sep 16, 2014 | 09:09 AM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
cut out sw.
I want the car to crank but not start how would you hook up a switch any help. Thanks.
Old Sep 16, 2014 | 09:48 AM
Joe Tag's Avatar
Re: cut out sw.
Put your switch on the pink wire from the ignition switch. It is power to the coil. Easiest to do this off of the steering column. You should be able to unpin it from the connector and use male and female spade connectors so you don't have to cut anything. Heat shrink and tape the end you unpin so it doesn't ground out anywhere.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
