cruise control computer bypas
Old Sep 21, 2014 | 07:49 PM
nater's Avatar
Car: 1984 camaro berlinetta
Engine: v8
is there any way to wire up the cruise control to work not using the computer. my car currently has a non-cc carb and as far as i know if the CEL is on the cruise control wont work.
also what gear should the tcc engage or is it a specific speed, from stock. i am looking to install the tc-lockup switch again but want to know if that puts it anywere close to stock.
Old Sep 21, 2014 | 09:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: cruise control computer bypas
https://www.thirdgen.org/forums/engi...-function.html
JamesC
Old Sep 22, 2014 | 08:39 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Does it matter if the cluster is digital? His description says it's an '84 Berlinetta.
Old Sep 22, 2014 | 09:29 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
NO. Pulling the ECM / Harness should NOT effect the Cruise Control in any way,... at least in the digital Berlinetta !
The entire ECM & ECM harness can be removed from a Digital Berlinetta and the Speedometer and VSS Buffer will still work normally. In the Berlinetta the VSS Buffer gets it's ground from the same circuit as the Light Driver, Cig Lighter. Radio, and Audio Alarm.
Old Sep 22, 2014 | 09:39 AM
Scorpner's Avatar
Engine: V6, V8
Good to know. Thanks for the info!
Old Sep 24, 2014 | 09:55 AM
nater's Avatar
Engine: v8
mine still has the ecm it just doesnt control the carb anymore so should my cc work then anyway even with the CEL on and the computer pluged in or should i still ground it, and will that affect other things. i want to keep the computer incase i find a ccc to put back in it. i recently swiched cars it still the same model just with the v8. my v6 had the ccc but some sensors were bad so it didnt do much but run rich. the v6 cc didnt work and i was told it was because the CEL was on, i havent gotten to test it with the new car i just thought it would be the same situation since i dont have a working ccc in either car.
by the way thanks for the replys. i really hope this will work
Old Sep 25, 2014 | 11:57 AM
John in RI's Avatar
........so should my cc work then anyway even with the CEL on and the computer pluged in or should i still ground it, and will that affect other things.
Even if you completely remove the ECM and harness - the CC and the VSS buffer still have ground - you don't need to ground anything - so nothing will be effected.
........i was told it was because the CEL was on...
You were miss-informed. The only way the CEL could possibly/MAYBE effect the CC system is if there is a major VACUUM leak. The vacuum leak could cause a CEL AND cause the cruise not to work properly. There is no "electrical" interaction between the ECM and the CC other than indirectly ( by obtaining speed data from the same source; the VSS Buffer).
Old Sep 26, 2014 | 09:00 AM
nater's Avatar
Engine: v8
ok thanks guys. my v6 had lots of problems so this doesnt realy surprise me. i should be getting the v8 back on the raod this weekend so ill test it then.
Hotrodboba400
Dec 10, 2019 07:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
