86 tpi cruise control servo wire snapped on servo
Old Nov 5, 2014 | 07:11 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Was driving on the highway with cruise and had to slow up. After speeding back up, I attempted to reset the cruise and it wouldnt come back on ever since. No cruise functions work. However everything else on the lever does.
Recently I installed new vacuum lines to the canister. They're a little loose but not enough to cause a leak.
What is the cause for complete failure? Will check the gages fuse today. The brake lights do come on.
Also I have never worked with this system before. Been looking up threads on here and have no idea what or where the servo or module is.
Thanks!
Old Nov 5, 2014 | 05:56 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Re: 86 tpi cruise control
Found out the line going from the firewall to the servo snappedName:  20141105_175208_zpsgnkzdhzm.jpg
What is my course of action here? How is that line supposed to be installed. There's multiple holes so I'm not sure which one it snapped off.
Will I need a whole new servo?
Old Nov 5, 2014 | 07:21 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 86 tpi cruise control servo wire snapped on servo
If the pin at the end of the cable is busted off, you'll need to replace the cable,... or 'rig' the cable to stay in the correct position some how. IIRC The pin should fit thru the hole and a washer/cotter pin thru the pin holds it in place.
IMO ---------> Looking at the pic it sure looks like the pin was set at the hole in the middle of the top row. I'd re-install the cable there first and then check operation.
Old Nov 6, 2014 | 01:22 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Has been a downpour here recently so I didn't even notice the washer mark *head slap*
Since finding that cable has been a pita to find online I'll try and rig it up today
Thanks for the reply!
Old Nov 17, 2014 | 11:34 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Fixed it. Just like factory too
Not too worried about how it look . Works great again
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
