Dash oil and temp signals - voltage signals?
Old Nov 28, 2014 | 12:00 PM
di11on's Avatar
Hi folks,
I'm working on a project to make electronics for a KITT dash and am wondering if anyone has any info about the oil pressure and temperature signals on a 3rd gen Firebird.
I know the fuel gauage is an Ohm signal with 90 Ohms representing a full tank.
Are the oil and temp signals voltage signals? With 12V for max temp and max oil pressure? If not, does anyone know how I might find out?
Thanks in advance
Old Nov 28, 2014 | 12:38 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Dash oil and temp signals - voltage signals?
Yes, they both use voltage signals. However, it's only 5v, not 12v. The 5v reference signal is provided by the ECM.
Old Nov 28, 2014 | 12:44 PM
di11on's Avatar
Great! Thanks a million - that's what I wanted to know!
Do you know where I'd find details of the speedo signal? I know it's a pulsed signal.
Thanks again
Old Nov 28, 2014 | 02:03 PM
OrangeBird's Avatar
Car: 1989 Firebird
Totally wrong !
To the OP , I PROMISE you that the ECM has exactly NOTHING to do with the functioning of the gauges in question !!!!!!
Old Nov 28, 2014 | 05:46 PM
di11on's Avatar
Totally wrong !
To the OP , PLEASE consult the schematic diagrams located at www.austinthirdgen.com for the correct information about how your temp and oil pressure gauges are wired .
Hey Orangebird - thanks for this. austinthirdgen.com doesn't appear to exist and http://www.austinthirdgen.org/ is giving me errors. You wouldn't happen to have an alternative link or even send them on to me if you have them stored locally?
Edit: Never mind - I found this (on this site) http://www.austinthirdgen.org/mkport...uges_part2.gif
Looks like they're all Ohm signals.
Anyone know if they're 90 Ohm like the fuel gauge?
Old Nov 28, 2014 | 06:09 PM
OrangeBird's Avatar
Car: 1989 Firebird
Hey , sorry for the bad link , I'll try to do it right this time
www.austinthirdgen.org/index.php?pid=19
Old Nov 28, 2014 | 06:13 PM
OrangeBird's Avatar
Car: 1989 Firebird
Cool , You found it ! Now , as you can see , there is no ECM involvement in the gauges . As to the Ohm ratings my best suggestion is to get an ohm meter and measure the senders . The temp sender I'd measure stone cold , and then at operating temp , the oil with the engine not running , and then with it running (right after having been started cold , when the oil pressure would be it's highest) . This would give you the approximate operating ranges for the senders and I hope that's what you were needing ?
Old Nov 28, 2014 | 09:16 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Sorry about that. I was looking at the wiring diagram for the coolant temp sensor for the fans, not the gauges.
89GTAOz
May 16, 2020 09:31 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
