Lighting problem
Old Dec 2, 2014 | 07:09 PM
Camaro_383's Avatar
Car: 92 25th Anniversary RS
Engine: 5.0 TBI 305
Lighting problem
Hi, I have a 92 RS with the 5.0 TBI engine.
Recently, when I go to turn on my headlights none of my gauge lights work and the backlight for the radio is completely black instead of only dimming like it should. I'm edging towards it just being a fuse problem. If it is, what fuse would that be? Or if it's something else, what could it be?
Thanks in advance!
Old Dec 2, 2014 | 08:06 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Lighting problem
Thanks in advance!
For sure check the "inst lps" 5 amp fuse in the fuse panel under the dash . If blown , and blows again when replaced with another 5 amp fuse try unplugging the radio before trying it again .
The radio going dark is not normal , especially when you figure that no power to the instrument lamps should mean no power to the radio's display dimmer circuit . So why would it do anything if getting no power ? Shouldn't it just stay at normal daytime brightness since nothing is "telling" it to dim ?
Good Luck with it and report back with your findings
Old Dec 29, 2014 | 03:40 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fuse Ruse
Your fuses appear OK.
You most likely have a Headlight Switch problem.
To verify use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to probe the orange wire at the switch.
Is there power there?
If yes probe the
brown wire on the switch when the switch is in the on position.
Happy Racing !
We Keep The Air Wrench Shiny So It Looks Good When We Throw It Across The Pit Box
Old Dec 29, 2014 | 07:20 PM
92formulalukain's Avatar
Car: 92 firebird formula
can u guys help me out i have a 1992 firebird formula everything worked great on it and i noticed last night wen i opened the door the dome light didnt come in well i thought no biggie got in she started up as usual but wen i hit the head lights theres like no power i replaced the light switch and have checked fuses the motors wont run or nothin for park lamps or headlamps plzzzz hel;p
Old Apr 20, 2015 | 07:48 PM
Roblen91GTA's Avatar
Car: 1991 Trans am GTA
i have a similar problem, when my headlights are on my radio lights go out but dash lights stay on and i replaced the headlights switch with no success
Old Apr 20, 2015 | 07:53 PM
Its the fusable links in front of the starter may appear fine but burns into internally
Old Apr 20, 2015 | 08:15 PM
you think i should check that? ive checked everything possible under the dash and even swapped the radio out to confirm its not the radio acting up
Old Apr 20, 2015 | 08:25 PM
Yes its just 3main hots i cut the links all the way out n wired heavy gauge wire and a big car audio amp fuse and did away with the links completlely no more issues theyre red n orange
Old Apr 20, 2015 | 08:30 PM
ok cool i will check that out now. i was also reading up on the remote dimmer located on the driver side under dash panel, do you think it could be that?
Old Apr 20, 2015 | 08:31 PM
Good possibility u can check it with a ohm tester
Old Apr 20, 2015 | 08:38 PM
yeah i have a feeling its that. can you explain how to ohm test it and i'll go test it now and report the reading back. should i remove it to test it because i actually have the under dash apart
Old Apr 20, 2015 | 09:07 PM
ok so i probed the harness to the remote dimmer and got about 30.0 ohms on a 200 scale and when i connected to the remote dimmer itself on all 3 prongs it was infinite like no reading and tried different scales and got the same reading so whats the sounds like to you?
Old Apr 21, 2015 | 03:30 PM
Camaro_383's Avatar
Engine: 5.0 TBI 305
I've had the dome light problem before but in my Camaro. If you also noticed, your door locks and cigarette lighter doesn't work too (that's if the firebird is set up the same). There should be a 20 amp fuse that ties all 3 of those in together. Idk about your motors on the other hand because idk if the Firebirds are set up the same
Old Apr 21, 2015 | 03:32 PM
Camaro_383's Avatar
Engine: 5.0 TBI 305
Is this remote dimmer you speak of only for Firebirds or for both? If so where did you say it was? Maybe that is my problem also
Old Apr 21, 2015 | 05:39 PM
http://www.cvpi.org/archives/p71inte.../wsdindex.html
this is where i found the info but looks like only firebird/trans am. its hidden too, it was under the dash near the fuse box but this was on my 91 gta not sure about the camaros
Old Apr 21, 2015 | 11:00 PM
seriously wtf the remote dimmer did not work!!!
92formulalukain, i'm now desprite and back to what you said about the fuseable links near the starter. how often do these burn out? and were you having this problem when you replaced yours with the heavy gauge wire and big car audio amp fuse?
TheJoeY88
Dec 31, 2016 07:30 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
