LED Light Replacement
Old Jan 22, 2015 | 01:31 PM
Swingblade's Avatar
Car: 87 Trans Am
Transmission: Automatic
Hey everyone, I've been looking through the forum trying to gather information on how to convert my tail lights to LED. I know that in order to get the turn signals to work I will need to use a new flasher relay or resistor. It seems to be easier to put in a new LED flasher relay but I am having trouble finding the one that will fit my 87 Trans Am. I am not intending to convert all of my lights to LED, just the rear lights and possibly the two front turn signals. The side markers will remain the same.
My questions: which one should I use? If there is a relay that will work for this, does anyone have a link to it or where can I buy one? Thanks!
Old Jan 22, 2015 | 05:26 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Re: LED Light Replacement
I used a Superbrite led lights an a heavy duty flasher from AutoZone an they work great taillight's all dash lights no front turn sig.
Old Jan 22, 2015 | 06:26 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Noth shure for the 87, this is on a 91
https://www.thirdgen.org/forums/elec...er-v-turn.html
Old Jan 22, 2015 | 06:30 PM
Swingblade's Avatar
Car: 87 Trans Am
Yeah the 87 looks a little different. Not sure how I would run the ground wire or if that relay would even work.
Old Jan 23, 2015 | 03:54 AM
thomas1976's Avatar
Car: 91 Trans am
The OE flashers have no ground wires, I connected the LED flasher ground wires to the little screws you can see in the pic.
Do you have a pic of the flashers used on the 87?
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
fonzie85
Aug 13, 2015 11:50 AM
Omega
Aug 10, 2015 12:46 PM
