Right turn signal = reverse lights?
Old Jan 31, 2015 | 04:56 PM
KrogerFatality's Avatar
Hey guys. 1986 trans am firebird 305, manual. Like the title says, turn signal doesn't work when activated, the reverse lights come on instead. What do I do?
Old Feb 1, 2015 | 10:35 PM
Re: Right turn signal = reverse lights?
Bump. I need serious help here guys. Please
Old Feb 2, 2015 | 03:41 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Reverse Reality
Did you recently buy the car?
It sounds like someone did some “rewiring” to cause that problem to happen.
You will have to physically trace the backup lights circuit to find where the wire(s) have been tapped into.
You can start at the left rear of the car where you will find the connector for the taillight assembly.
Unplug the connector and probe the forward connector.
Connect the probes between the
light green wire and ground.
Now, activate the right turn signal.
Is there power on the probed wire when you do that?
If no, the problem is in the wiring in the taillight assembly.
If yes, the problem is in the remainder of the car.
Happy Racing !
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Feb 2, 2015 | 05:19 PM
I've had the car for a while, this happens out of nowhere
Old Feb 2, 2015 | 08:03 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
Fronzizzle
Mar 18, 2019 08:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
