need help switchback signal lights
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
Can someone tell me what I have to do to get front switchback signal lights to work? Or what wires the resistors go on? Here is what I have
Re: need help switchback signal lights
What behavior are you trying to produce?
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
got it now! this is what it looks like
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Resistor goes between/crosses (jumper for resistance)the ground wire and the turn signal power wire..
Ok , so I'm forced to ask this one question ;Where I live , the police have a thing about anyone having anything that looks even remotely like "wig wag" headlights , like they have . Now I realize this is one side only , during turn signal use , but what of 4 way "emergency" flashers ? Isn't that going to alternate both headlights with both front turn signals ? If so , and an officer ever sees you driving with the 4 ways on , Here they call that "impersonating an officer" and the fines are huge .
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
not sure orangebird! haven't got to that part of the show yet lol
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Could build a Synchronized front parking/turn light and side marker relay, to have them in sync.
http://www.dailymotion.com/video/x1atf7s_side-marker-sync-relay-480p_tech
https://www.thirdgen.org/forums/elec...king-turn.html
