Need help with wiper fluid pump
Old Mar 12, 2015 | 01:42 AM
E Rod's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8 X V6
Transmission: 4 speed Auto
Hi ever since I bought my firebird one of the 2 or 3 things wrong with it was it was unable to spray washer fluid. I replace the pump but it did nothing so I took it to a mechanic and after throwing out $120 the mechanic told me the wiper motor cover or what ever the **** this thing is
Was broken (my fault) they told me they can't find one. Can anyone tell me what this parts is actually called and how much it would cost to replace
Old Mar 12, 2015 | 10:06 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Need help with wiper fluid pump
wiper motor cover..... and good luck
Old Mar 14, 2015 | 01:38 AM
E Rod's Avatar
Engine: 2.8 X V6
Thanks for the info. Now to buy the part and find a shop to install it
Old Mar 17, 2015 | 04:12 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
All Pumped Up
Let’s say you can’t find a working cover.
You can install a switch to activate the washer pump.
You can even connect it thru a timer so you can merely touch the button and the washer pump stays on for a few seconds.
Happy Racing !
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
backtothe80s
Sep 5, 2015 12:39 AM
Randomtask2
Aug 26, 2015 03:34 PM
92camaroJoe
Aug 13, 2015 06:07 AM
slade5612
Aug 11, 2015 07:19 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
