87 iroc - wiring harness to AC compressor question
Old Mar 24, 2015 | 10:05 AM
ndz's Avatar
ndz
Car: 1987 Camaro Iroc / 1970 Camaro Z28
I was in the midst of doing valve seals on my 87 iroc 5.7 tpi this weekend when I had to move the AC compressor to get the driver side valve cover off. At that time, I found the wiring harness leading to the AC compressor had 2 of 3 connectors disconnected. The AC compressor was connected but it appeared that the driver side temp was unplugged and there was one additional plug that was not plugged in anywhere. It looks like its been unplugged for some time and I cant figure out where it goes. Any help? Its one of the three plugs that is on the end of the stock harness leading back from the AC compressor....
Old Mar 25, 2015 | 07:55 AM
ndz's Avatar
ndz
Re: 87 iroc - wiring harness to AC compressor question
Took a pic of the harness last night. Looks like one for sure is the temp sending unit from driver side, the other I am not sure of...Name:  IMG_3402_zpsxglepgur.jpg
ndz's Avatar
ndz
Old Mar 25, 2015 | 08:14 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Second pic looks like the one that connect to the AC unit
Old Mar 25, 2015 | 08:16 AM
ndz's Avatar
ndz
In the first pic on the lower left you may make out that the AC compressor is plugged to one of the three ends of that harness. Does the AC compressor have 2 connections?
Old Mar 25, 2015 | 08:20 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Opposite of yours, but notice that plug at the TOP of the AC
Old Mar 25, 2015 | 08:22 AM
ndz's Avatar
ndz
got it, must be an electronic connection for the clutch to engage/cycle the compressor?
Old Mar 25, 2015 | 08:24 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
YES, the one in your pics is a pressure switch, my pic shows the power. If you unwrap the crappy GM tape job, you'll see they have a diode in there
Old Mar 25, 2015 | 08:25 AM
ndz's Avatar
ndz
Great! Thanks that solves it. You are right on. I noticed the diode. Thanks
Old Mar 25, 2015 | 08:27 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
You bet!
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
armybyrd
Dec 5, 2015 09:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 11, 2015 03:17 PM
