cold start injector help
Old Mar 29, 2015 | 02:53 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
i dont think my cold start injector is working ... what tells the computer to use it ... how many volts does it take to open it ... if i cant get it to open with the computer, i will wire it so i can open it when i need it, but i dont want to over power it and burn it up
Old Mar 29, 2015 | 06:59 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: cold start injector help
Cold Start is not ECM controlled. Should be able to figure out why it's not working with a voltmeter in about 5 minutes.
A bad ground from CSS to intake,.... a bad CSS,.... or lack of power will cause no Cold Start operation.
Check the purple/white wire @ the Cold Start injector when a 'helper' starts the car. If there's no battery voltage: Check the CRANK fuse. The voltage gets sent from there during start-up to the Cold Start Switch on the front (coolant port) of the intake manifold & the Cold Start Injector using the same circuit. ( The CRANK fuse GETS it's power - only while the key is turned to START - from the PURPLE wire @ NSS for Automatic,.... or the Clutch Start Safety Switch in a stick. )
The Cold Start Switch should only provide ground to activate Cold Start Injector ( ground = Tan wire ) if the engine temps are cold.
Old Mar 29, 2015 | 08:39 PM
Barlow8869's Avatar
ok, thank you ... i will see if i can find the css (my first tpi car) and check the things you pointed out
Old Mar 30, 2015 | 10:34 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tpi/669731-tune-port-cold-start.html
Old Mar 31, 2015 | 01:31 AM
Barlow8869's Avatar
thank you tuned, that will help a bunch ... now just need a day off to get on it ... working 2nd shift 6 days a week dont leave much time to work on the gta
Old Mar 31, 2015 | 06:36 PM
Engine: Lb9
Transmission: M20
Or I can tune it out
Old Apr 1, 2015 | 09:04 AM
Barlow8869's Avatar
i wish i could have you do a tune, i just dont have the cash for it right now
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
