Distributors. Many questions..
Bought a 89' Formula a couple year ago with a locked up 350 TBI. With the assist from a couple buddies, I've been slowly building a 383 for it. Well, I'm starting to get serious about it, and I am at the point of picking a distributor.
At this point, I have been recommended 2 different MSD distributors. The 8365 and the 8394. I can get the GM version of the 8365 for $340 but one of my buddies isn't certain that being it's a big cap design, that it will clear the firewall; he is recommending the 8394, which is $90 more and I would also need a coil.
Are you guys having fitment issues with large cap distributors? I really don't want to spend an extra $140 if I don't have to.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Distributors. Many questions..
Assuming you are going carb.
Honestly any HEI with a vacuum advance will work fine. I know people with the large cap fitting just fine with a carb in a thirdgen.
This will suit your needs
http://www.summitracing.com/parts/su...rNrBoCHCDw_wcB
Lots of pictures here for reference
https://www.thirdgen.org/forums/carb...ml#post5898255
Your assumption is correct, sir; it is being converted to a carb.
You have been ridiculously helpful!
