No power at and fuses for headlights
Old Apr 14, 2015 | 07:50 PM
Shiozaki's Avatar
Car: 87' Camaro RS.
Engine: .030 over 71' 307
Transmission: t-5
Edit:
https://www.thirdgen.org/forums/electronics/204059-camaro-headlight-problem-wont.html
This guy is having same problem as I.
Would it be safe to run a new wire from the battery to the switch, if there is not power at switch?.
Would it be advisable to add a in line fuse ?
87 v6 FI 5speed car converted to V8 carb 5speed car.
Every other fuse has power but the row with the head/tail lights fuse, no idea what's going on not sure how to fix.
Will take pictures when I'm home from work.
Old Apr 15, 2015 | 09:28 PM
Shiozaki's Avatar
Car: 87' Camaro RS.
Transmission: t-5
Re: No power at and fuses for headlights
Bump with more info
Old Apr 15, 2015 | 11:14 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Any chance of testing the fusible links down by the starter? Betting one is bad.
Old Apr 15, 2015 | 11:23 PM
Shiozaki's Avatar
Car: 87' Camaro RS.
Transmission: t-5
Alright alright, buddy of mine said the same thing, so where are they? And why dose one look like ?
Old Apr 17, 2015 | 05:20 PM
Shiozaki's Avatar
Car: 87' Camaro RS.
Transmission: t-5
Pulled the engine harness, checked every wire, crap junk yard harness but from whatnot could tell all the wires that were there getting power was making it to the plug.
Could I have the wrong year harness, or one from a firebird ?
I got to the headlight switch what a pain.
It's getting no power at the switch, jumped power to switch from battery and lights started working....
I could really use some help guys.
Old Apr 17, 2015 | 11:35 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
picture of a fusible link post#55
https://www.thirdgen.org/forums/afte...y-power-2.html
Make sure you are getting power (12v) on both sides of the links at the starter.
Old Apr 18, 2015 | 12:05 AM
Shiozaki's Avatar
Car: 87' Camaro RS.
Transmission: t-5
As I said above every wire getting power is making it to the fire wall plug.
Either I'm missing a wire or something.
What wire powers the lights.
Where on the plug to the fire wall is the power going to the switch.
Old Apr 18, 2015 | 01:05 AM
Car: 91 z28
Transmission: 4L60e
Did you check the fusible links with a multi meter?
C100 G5- check for 12v
http://www.austinthirdgen.org/mkport..._1987_C100.gif
Old Apr 18, 2015 | 05:19 PM
Shiozaki's Avatar
Car: 87' Camaro RS.
Transmission: t-5
thanks a million I been trying to find a diagram like that, guess I'll go buy a multimeter, up to this point I was using a test light.
Old Apr 21, 2015 | 09:50 AM
Shiozaki's Avatar
Car: 87' Camaro RS.
Transmission: t-5
i attached a pic, is it just me or is g5 missing and g4 is being used?
Attached Thumbnails No power at and fuses for headlights-20150421_083836-1-.jpg
Old Apr 22, 2015 | 05:53 AM
Shiozaki's Avatar
Car: 87' Camaro RS.
Transmission: t-5
bump
Old Apr 22, 2015 | 06:51 AM
TTOP350's Avatar
That pic is absolutely 0 help to us playing the home game.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 13, 2015 12:59 PM
