trying to wire alternator
Old Apr 17, 2015 | 03:32 PM
camsuper88's Avatar
Car: 88 iroc-z camaro
Engine: 305 tbi
Axle/Gears: idk
i just replaced the battery, alternator and starter and now im having trouble wiring it all. i have the battery positive to the starter large terminal and the alternator outlet wire to the same place. when i try to hook the positive terminal to the battery i get alot of sparks. is this normal? where should the battery negative be grounded. is it grounded in the wrong spot or not grounded at all?
Old Apr 17, 2015 | 11:44 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: trying to wire alternator
correct, incorrect alt should go to batt pos, yes, engine Large gauge-chassis smaller gauge
92 but will give you the gist
http://www.austinthirdgen.org/mkport...F_and_vin8.jpg
Old Apr 19, 2015 | 06:21 PM
camsuper88's Avatar
Engine: 305 tbi
Axle/Gears: idk
i found out that i blew out the stock alternator output wire. i made a new one with ten gauge wire. no matter which point i touch the output wire to i get lots of sparks from where i touch it too. i have no idea what is wrong or how to fix it. please help if any of you know whats wrong.
Old Jun 25, 2015 | 07:26 PM
camsuper88's Avatar
Engine: 305 tbi
Axle/Gears: idk
so the alternator was grounding to the valve cover cause it was to close. so i banged in the cover abit and put more isulator on the terminal and i was good to go.
Old Jun 29, 2015 | 11:11 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You can usually find a rubber boot that covers it. Most auto parts stores carry them and they come stock on nearly every car.
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
