injectors aren't firing
Old May 12, 2015 | 04:05 PM
Moore89's Avatar
If I spray starting fluid it will start but won't star running if I feather the throttle it will run for a little bit before it died the injectors start spraying after I hit it with starting fluid
Old May 12, 2015 | 04:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: injectors aren't firing
check your fuel pressure and ohm your injectors !
Old May 12, 2015 | 04:57 PM
Moore89's Avatar
Old May 12, 2015 | 05:02 PM
Engine: Lb9
Transmission: M20
is this tbi, tpi or a v6 ?
tbi is 2.5 Ohms
tpi 16 1/2-18 1/2
Old May 12, 2015 | 05:03 PM
Moore89's Avatar
350 tbi
Old May 12, 2015 | 05:24 PM
Moore89's Avatar
So what now
Old May 12, 2015 | 05:27 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tbi/...o-rs-wont.html
Old May 12, 2015 | 05:35 PM
Moore89's Avatar
I've had it at the dealership they said it was the computer or the distributor I put a different distributor in still the same thing swapped the ecm still the same thing
Old May 12, 2015 | 09:14 PM
Engine: Lb9
Transmission: M20
Sounds like the low impedance/shorted injectors are shutting down the injector driver.
If you had someone diagnose it why isn't it fixed ?
Old May 12, 2015 | 09:20 PM
Moore89's Avatar
Dealer wanted 300 to put in a distributor and 300 more to put in ecm and it doesn't look like it's either of those
Old May 12, 2015 | 09:28 PM
Engine: Lb9
Transmission: M20
You might want to try the tests on the other thread. Unplug both injectors and use a tbi noid light to check for injector pulse. Then read the post bye Rbob.
If this is a 89-92 tbi it's a 1228746 ECM read the post I put on messing the voltage on the vats wire. If this is a 88 it's a odd ball ECM. You can upgrade plug and play to the 746 ECM and use a caprice tune for a 350. eBay has standard motor products 350 injectors tj7j for under $100 a set.
Old May 12, 2015 | 09:32 PM
Moore89's Avatar
Mines a 91 I swapped ecms and it's doin the same thing and the dealer fixed the vats problem are you sayin the injectors could be bad
Old May 12, 2015 | 09:48 PM
Engine: Lb9
Transmission: M20
Iirc tbi injectors are 2.5 ohms . Regardless unless you have a custom tune and the 65#hr injectors you engine will run lean. Read the testing procedures on the other thread. I would still eliminate the ECM is getting a drp , vats signal is getting to the ECM, both injectors unplugged and a noid light is used to test injector pulse.
Even test that the ECM is powered up, if the mil comes on with the key in the on position it is powered up.
Old May 12, 2015 | 09:51 PM
Moore89's Avatar
I'll have to try and get some no I'd lights and what do you mean mil
Old May 12, 2015 | 10:09 PM
Engine: Lb9
Transmission: M20
Mil=malfunction indicator lamp
Amazon.com: OTC 7187 TBI Noid Lite for GM: Automotive Amazon.com: OTC 7187 TBI Noid Lite for GM: Automotive
Old May 12, 2015 | 10:11 PM
Moore89's Avatar
Probably rent them from OReillys or buy um there so what is the nod light gonna tell me
Old May 12, 2015 | 10:14 PM
Engine: Lb9
Transmission: M20
The noid light is going to tell you if you have injector pulse without the injectors plug in.
Old May 12, 2015 | 10:15 PM
Moore89's Avatar
And then what happens
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
rsrookie
Sep 5, 2015 07:08 PM
