Horn not working
Old Jun 7, 2015 | 06:09 AM
Humphrey Lees's Avatar
Car: '82 Camaro
Engine: 305ci (SUJ) not crossfire
Transmission: TH350
Axle/Gears: Stock
Horn not working
It was working before I changed the speedometer cable and changed the cluster.
Could I have pulled out a connection?
Where can I find the horn relay so I can trace the line back? There is no click from a relay, so the grounding signal is not getting there.
Humphrey
Old Jun 7, 2015 | 05:47 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Horn not working
Humphrey
Hi Humphrey ,
On my 89 , I found the horn relay in the convenience center which is under the driver's side dashboard to the right of the steering column . There will be a blinker unit for the 4way lights and the sounder unit for the seat belt warning on the same electrical sub panel also .
If you can't find it , a search for "convenience center location" here may turn up pictures of exactly where it is .
Old Jun 8, 2015 | 05:36 AM
Car: '82 Camaro
Transmission: TH350
Axle/Gears: Stock
It was only a fuse. Thanks for pointing me in the right direction.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
