Extra slots in the fuse panel
Old Jun 19, 2015 | 11:14 AM
dcd2236's Avatar
Car: 1987 trans am, 1988 Formula
Engine: 305 LG4, 305 LB9 TPI
Transmission: 700R4 in both
I have a couple extra slots in the fuse panel that I would like to in the future be able to hook something into them. I have 3 blank slots where the power seat, power antenna and one other feature my car did not come with that looks to be tied into the main power. What would be the proper way to tie into these without shocking the crap out of me or setting fire to the car?
Old Jun 19, 2015 | 11:23 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Extra slots in the fuse panel
I got a friend in Trinity.
Just use a flat spade connector crimped to the proper size wire for your application along with an inline fuse for the new component
Old Jun 19, 2015 | 06:13 PM
skinny z's Avatar
You can also get fuse block connectors from Pico that fit into the slots labelled "ign" and "bat". They're specifically keyed for ignition and battery power. There's also one available for the gauge socket in the fuse block that can be used for aftermarket gauges and offer the same dimming functions as the factory lamps.
The Pico connector replaces the spade connector as was suggested earlier (which works very well by the way) and it'll be up to you to fuse it appropriately.
Veaceonee
Sep 29, 2016 08:15 PM
gta892000
Sep 16, 2015 12:37 AM
timonator
Sep 10, 2015 07:55 PM
64goatman
Sep 9, 2015 01:09 PM
84 TA NV
Sep 6, 2015 08:02 PM
