I have some serious problems need help ASAP
Ok here the car 89 Formula 350
Problem: when I turn my headlights on my tail lights, side markers, and front markers dont come on. The only time they do work is when I step on the brake the brake lights come on, and when I put the turn signals on they come on. other than that they dont work. I think I hvae read about this problem before and I rememberd that it was probably the INSTRU fuse thats in that seperate little black single fuse box. I checked that and the fuse (15) was still good. What else could it be? is it my rheostat>?
I need help with this as soon as possible as im driving to whyoming in the morning so I need it fixed TODAY
maybe yall need mroe info? daytime lights work fine, its the night time lights ( tail lights and what not ) the headlights work, and they pop up BUT they dont come back down The side markers and all dont work UNLESS I have my turn signal on then they blink when they are supposed to I REALLY need some help fast here some please help. I replaced the fuse thats just clipped to the fuse box hoping that woudl work but it didnt. what other fuses should I try? am I right about it being the rheostat?
Im not sure what wires touched or even if they did. its bugging me. My tail lights dont work, my headlights turn on but wont go down ( they do go up though ) and my lights on teh front end next to the headlights dont work unless I use the blinker, same with the tail lights they dont come on unless I brake or use the blinker.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The brake lights & turn signals are on a different switch than your makrker lights & the headlights are directly powered from the starter (big red wire)
The fuse that supplies the juice to the rest of the lights is the TAIL fuse. It should be a 20A fuse. If the fuse is not busted, you may have a switch problem.
Glowsock
Sep 6, 2015 06:40 AM
