Mini high torque starter wiring.
Old Sep 30, 2015 | 06:50 PM
3rd gen money's Avatar
Car: 1992 camaro rs
Engine: 383 stroker
Hi. I'm using the starter pictured and want to make sure I have it wired correctly because I can't get it to work when I turn the key. Most of the wires (including the fuse able links and wire from battery) are on the top post. There is a small purple wire on the bottom screw post. Is this correct?
Old Sep 30, 2015 | 09:58 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: Mini high torque starter wiring.
here
Old Sep 30, 2015 | 11:43 PM
Night rider327's Avatar
Car: 1988 Camaro
On the picture you posted, You add NOTHING onto the bottom large screw post. Only thing that goes to it, is the that that is on it, in that picture you posted.
Your fuseable links and all goes onto the top like you have it,
But your small ign. switch wire (I think it's purple) goes to the flat blade post on the left center in that pic you posted
Your starter as pictured uses a ring and spade terminal end setup rather than stock large/small ring.
You will need to cut the ring term off the one wire and crimp on a female spade that will plug onto the male spade post on your starter.
Old Oct 3, 2015 | 12:02 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Thanks Night. I didnt have an exact starter pic, but they for the most part are the same.
Old Oct 3, 2015 | 08:21 PM
Car: 1992 camaro rs
Engine: 383 stroker
Thanks. Works like a charm now!
Old Oct 4, 2015 | 01:48 AM
Car: 1988 Camaro
Your welcome..
Yeah Z28 they are all the same in the wiring, you are 100% spot on. Some just has a blade term and some has a ring term... The ones with the blade post trips up a lot of people because it is so different for a chevy, you know
Old Oct 11, 2019 | 09:57 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
I think im having the same problem.... but i dont quite understand.
armybyrd
Dec 5, 2015 09:22 AM
64goatman
Sep 9, 2015 01:09 PM
angel2794
Sep 8, 2015 06:22 PM
Stryker412
Sep 7, 2015 09:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
