power window wiring?
Old Oct 1, 2015 | 09:05 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
All of my 89 firebirds wiring for the windows is cut up. How much trouble is it to make it all work again? Does anyone have a schematic of the wiring in that area?
Old Oct 2, 2015 | 12:55 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: power window wiring?
Just (properly ) re-splice the wiring and check to see if the windows work.
If just repairing the wiring is all that's needed than it should be easy to resolve,... if the motors are bad than you'll have to take the door panels off to replace them.
Old Oct 2, 2015 | 10:03 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
If only it was that easy. There's like 50 wires near the shifter hole and the previous owner cut them pretty short. I'm considering trying the junkyard for the wiring from a 3rd gen.
Old Oct 2, 2015 | 06:06 PM
Bubbajones_ya's Avatar
Car: 1998 Viper/1996 Bronco
Engine: 8.0/7.3
Transmission: T56/ZF5
Well I don't have a schematic but if the wiring was cut only at the sifter hole, then you may be able to splice in a new harness fairly easily. It would be best to check for the harness at a junkyard, but the harness for the power windows/door locks is not too bad to separate (that is if the camaro and firebird harnesses are the same.)
The harness should plug into the main vehicle harness under the drivers kick panel and also a big relay. The rest of the wires go to the window regulators/door lock actuators, and switches.
The only wiring under the center console is for the two switches, which I believe have four wires each, and a small ground wire.
Old Oct 2, 2015 | 07:57 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
This is for a 86 Firebird TA ,Should be the same
Old Oct 3, 2015 | 09:25 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
One of the window switches.
Old Oct 4, 2015 | 11:27 AM
John in RI's Avatar
This is what your Power Window Switche wiring SHOULD look like.
None of the wiring in your last 2 pictures has anything to do with the power windows.
Old Oct 4, 2015 | 01:26 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Just grabbed the wiring from a junkyard today.
The other pics were of under the passenger side dash.
Old Oct 4, 2015 | 02:40 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
If you are still going to splice the wires, it's a good idea to offset them so they aren't as bulky. this also reduces the outside chance of a short later on.
Old Dec 5, 2015 | 09:22 AM
GASPEDDLER's Avatar
Merry Christmas from Deep South Texas.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
