battery drain
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
battery drain
I've got a very slow battery drain somewhere.
Can anyone think of a reason the battery won't charge while hooked up in the car but will when it's sitting on a block of wood on the floor?
Re: battery drain
No; unless your drain is more current than your charger can put out. In which case it might not be able to charge the batt at all but instead might just barely keep up with the drain.
Check things like lights for the drain... underhood light, interior lights, tonneau light (right at the hatch latch)
Car: '88 GTA
Re: battery drain
I think that's exactly what's happening. I'm going to hook up the volt meter and start pulling fuses today to see if I can find it.
dennisbernal91z
Oct 22, 2015 09:28 PM
firechiken47
Oct 10, 2015 06:16 PM
