Vss signal Help
Vss signal Help
Hi I may have discovered another issue in my Camaro build ,I have 91 camaro using 86 corvettte maf engine that requires 2000 vss signal for ecm .I am using the programmable dakota digital dash 4000 Vss signal .The speedo can be programed but how can I get the 2000 Vss signal to the computer. I think I saw on the buffer a place for 2000 or 4000 out put.My trans sender will be putting out 4000 required for the digital dash. Any help would sure be appreciated Thanks Mike
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Buffering
..Buffering
..Buffering
..Buffering
..Buffering
..Buffering
..Buffering
Terminal C1 of Buffer connector C2 puts out 2000PPM.
Happy Racing !
I Hit The Water Barrels Because My Car Was Dirty
Happy Racing !
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Vss signal Help
Under settings you can stop the scrolling to the next related thread. We have all done this 😆
luv2whelie
Mar 1, 2011 02:56 PM
