Ok another indicator issue
Old Mar 23, 2016 | 07:10 AM
Zac Tate's Avatar
84 Z28 ok here goes ,
the right indicator stays on
when the indicator is in use it now blinks real fast and dim then flashing and slow and strong then mixes all this up
the right does this
so does the left
when the hazards are on they blink side to side on inside due to the right indicator being on and all work ok on out side
also the volts have dropped the bottom and and the rev counter is on full and twitches when the indicators are on .
any help here would be awesome ,
like where to start to fix this
Old Apr 18, 2016 | 05:01 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash 4 Cash
The problem is consistent with a bad ground.
The
black ground wires come out of the dash connectors and go to the ‘Convenience Center’ bracket.
The Convenience Center is located behind the knee bolster.
The Convenience Center contains a the Hazard flasher among other parts
(just to help you identify it),
and is to the right of the steering column.
The bottom line is you have a bad connection from the indicator lamp sockets to ground, or indicator sockets to the signal side.
You might have a cracked circuit board trace (difficult to see).
You might have a loose or dirty contact on the connector(s) for that circuit.
Happy Racing !
Help Combat Global Cooling ▬ Accelerate As Fast As Possible
tater
Apr 28, 2016 04:30 PM
kaotik
Mar 26, 2016 05:35 PM
Donniemoss86
Mar 22, 2016 10:37 PM
neilcase
Mar 21, 2016 10:08 PM
oscarfromla
Mar 20, 2016 10:10 PM
