Another interesting fan problem
Old Apr 13, 2016 | 06:23 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I am using the stock 1987 (new) relay for the fan on the left side.
When I start the car in the morning the fan comes on right away.
I have replaced the CTS, I have changed the ECM, I have changed the memcal
The prom is programed to come on at 190 off at 186.
I have checked the wire for shorts, there are none.
I turn the key on and have 12 volts at the relay but the fan doesn't start until I start the motor.
I am lost on this one.
Anyone have some input?
Old Apr 13, 2016 | 06:30 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Another interesting fan problem
My only question would be ;
Could it be a failure in the heat/ac control ?
I know my fan will come on at any engine temp if I put the control to "Max AC" . If I leave the control in the Max AC position and shut the car off , the next day when I start it stone cold the fan comes right on as well .
Old Apr 18, 2016 | 06:45 PM
Dyno Don's Avatar
Turns out it was just a matter of clicking the right box in the chip program.
It can be normally open or normally closed in the fan control area.
I had it wrong.
789roby789
Carburetors
29
Apr 9, 2016 08:09 AM
Spolt
Apr 6, 2016 11:40 PM
x_man
Apr 6, 2016 08:38 PM
apie2546
Wheels and Tires
Mar 30, 2016 08:12 AM
BOTTLEDZ28
Mar 24, 2016 05:34 PM
