Hazards work, right turn signal doesnt
Old Apr 17, 2016 | 06:33 PM
Tempest89's Avatar
Car: 1989 Firebird Formula
Engine: 5.0L V8 305
With all lights on, the green arrow for the right turn signal stays on. Additionally, When using left or right signal, neither of them pulse. Also, i am getting no power to the right turn signal In the front or rear when I should be. Left side I have power. However, with my hazards on, everything is normal. Fuses are good. Very confused. Help please
Old Apr 17, 2016 | 10:38 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: Hazards work, right turn signal doesnt
Make sure the bulbs are good first.
Old Apr 25, 2016 | 05:08 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Plight
After you verify the bulbs ►a common mistake is people installing 2 filament bulbs 180° rotated.◄
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) key in the RUN position, turn stalk in the right position, probe the dark blue wire out of the column.
Is there power there?
If no, you need to get to the switch, probe it at the switch and if still no power replace the switch.
Happy Racing !
If We Don’t Get Cawt We Ain’t Cheatin’
Nutti
May 14, 2016 01:33 PM
tecboy
Car Audio
Apr 18, 2016 11:29 AM
siuol
Apr 16, 2016 07:09 AM
Tempest89
Apr 13, 2016 08:04 PM
neilcase
Apr 11, 2016 10:42 PM
