Starter Wiring
Old May 10, 2016 | 12:04 PM
knightinblackar's Avatar
Car: 1984 Firebird S/E
Engine: 1985 2.8 MPFI
Transmission: 1985 T5 5 speed manual
Axle/Gears: 3.42/4.03
Starter Wiring
Hey guys,
Need to know what the two wires with the fuseable links are for at the starter.
Starter has 4 wires
Purple - crank signal
Black - 12V from battery
Red - ?
Red - ?
This may help me sort out a problem I'm having with my gauges nightmare starter problems
Old May 10, 2016 | 12:36 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Starter Wiring
Short Answer: They power most of the car.
85 doesn't show to have the 2.8L option, so that's an 86.
Old May 10, 2016 | 12:51 PM
thtanner's Avatar
Re: Starter Wiring
Here's the 'POWER DISTRIBUTION' page it refers to
This site has the entire manual for the most part: http://92b4crs.tripod.com/86wiring/86wiringindex.html
Old May 11, 2016 | 08:55 AM
Re: Starter Wiring
The 2 red wires carry power to THE ENTIRE REST OF THE CAR, besides the starter motor and alternator (and in certain engine combos, the ECM).
Each one feeds about half of the car. For example the ignition switch has 2 batt inputs off of one of them that it then distributes to switched things, which include the A/C, starter, gauges, radio, and .... ignition; the headlight switch connects to one of them; the brake lights, power seats, mirrors, door locks, interior lights, and all that, each get fed from one or the other; etc.
Therefore if one of the fusible links is bad, about half of the car won't have power.
Hook them up. If they're bad, replace them. http://www.summitracing.com/parts/rnb-85621
Old May 11, 2016 | 11:26 AM
Re: Starter Wiring
Well I have power windows, headlights, main beam, marker lights, turn signals, tail lights, brake lights, reverse lights, interior lights, crank, horn, although a bit weak, blower motor, and all fuses are ok, not blown and there is power to all of them!!
When I tested the fuseable links for continuity they both checked out.
Old May 11, 2016 | 11:28 AM
Re: Starter Wiring
Which circuits are powered by the power distribution post behind the passenger side headlight?
Old Apr 27, 2021 | 10:45 PM
Austyn Olson's Avatar
Car: 1989 base model firebird
Engine: 2.8 v6
Transmission: Automatic
Re: Starter Wiring
Does anybody have a wiring chart for for a 89 pontiac firebird? There were 5 wires to go with 3 posts on the solenoid for the starter, 4 of which are big electrical connections. I got sucked back into work and I can't remember where I took which ones off, I wired it back to how I thought it was an nothing happened when I tried to start it (it is a 2.8 liter v6) any help is appreciated
Old Apr 28, 2021 | 05:23 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Starter Wiring
The 4 big ones go to the big terminal on the top of the solenoid (the bottom big solenoid terminal goes to the starter motor itself) and the one small (purple) wire goes to the small terminal marked "S" . The small terminal marked "I" is not used...
Old Apr 28, 2021 | 07:19 PM
Engine: 2.8 v6
Re: Starter Wiring
You are what most people would call a Saint, she's alive! Angry, But alive. Thank you
Old Apr 29, 2021 | 05:08 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Starter Wiring
Your welcome and I'm glad you got it going.
Rbward21
Apr 30, 2016 08:42 AM
Wehrlebirdd
Apr 24, 2016 08:20 PM
L695speed
Apr 22, 2016 11:19 AM
racerx520
Apr 13, 2016 09:54 AM
Chough262
Apr 10, 2016 01:20 PM
