Battery wire
Old Apr 29, 2021 | 02:19 PM
BytePaul's Avatar
Transmission: ...was received.
Battery wire
Okay, I have a 92 z and I'm replacing the battery wires and going with a top mount battery. I was debating whether to get 2 AWG or 4 AWG. Does it matter what output my alternator has? I have ac also. Any recommendations? I know it depends on what one has installed.
Thanks in advance for any help!
Old Apr 29, 2021 | 02:55 PM
vorteciroc's Avatar
Top Answer: 1
Re: Battery wire
There is no harm in using a larger cable.
Is your vehicle completely stock?
Have you added any electrical accessories?
If not, 4 gauge is perfectly fine.
Also increasing the size of the positive cable from the Battery to the Alternator is good to do.
As well as adding the same size cable as a negative connection from the body of the Alternator to the Negative Battery Terminal.
Old Apr 29, 2021 | 06:13 PM
BytePaul's Avatar
Re: Battery wire
No, the car is not completely stock. I have not added, nor have I noticed, any additional accessories that have been added. Can't say what I'll add later though. Duly noted for the increase in cables. I think I will just get the 2 AWG and be on the safe side. Thank you!
Jordan Dorn
Jun 7, 2018 08:34 PM
IfknROC85
May 25, 2010 11:04 AM
camaroracer85
Car Audio
Oct 10, 2006 05:21 PM
mean57
Jan 29, 2006 10:31 AM
89 CamaroIROCZ
Jul 7, 2002 10:41 PM
