8625 pcm with 89 tpi
Old May 15, 2016 | 04:34 AM
Theratt1's Avatar
Hello everyone. I have moates apu1 and plenty of chips. I'm helping a buddy swap a tpi 305 into an 89 camaro. I've got an 8625 pcm and tpi wiring harness. The precious idiots who messed with this car screwed it all up. I have so far swapped over to a tpi harness and am in the middle of converting the harness over to an 8625 pcm from a 93 tbi truck that I have sitting around. The injector bank is .4 ohms. My main question is can I run high impedance injectors on this pcm without having to bypass the peak and hold setup. I know over 4 amps of current draw it will revert to peak and hold for tbi. It's a 700r4 trans I'm going to be using a tbi bbnt prom and converting it to tpi injection.
Old May 15, 2016 | 04:42 AM
Theratt1's Avatar
Re: 8625 pcm with 89 tpi
Also each injector is 2 ohms so can I run it in 8 ohm series?
Old May 17, 2016 | 09:14 PM
Theratt1's Avatar
Decided to actually get a tpi pcm. A 7165 and a couple questions about what memcal to use. Can I use a 305 tbi memcal as long as I run a prom for tpi? Or will this cause issues in timing?
Mattkovitch
Jun 6, 2016 09:35 AM
upon2
Mar 20, 2016 09:09 PM
Onion
Mar 19, 2016 03:08 PM
thorpe991
Mar 18, 2016 10:21 AM
JL2000
Mar 16, 2016 05:26 PM
