no start
Old Jul 7, 2016 | 02:48 PM
stegal's Avatar
Car: 1990 RS, 2002 Chev Silverado
no start
changed ignition coil and ignition control module. still no start. any ideas?
Old Jul 7, 2016 | 03:36 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Startling Startless
Did you replace those parts because you tested for spark and had none and still have none?
If yes, disconnect the 2 terminal connector at the distributor.
With the ignition in the RUN position, check for power on both pins of the harness.
Is there power there?
Happy Racing !
8 Cylinders, No Waiting
Old Jul 7, 2016 | 03:56 PM
stegal's Avatar
Re: Startling Startless
which two terminal connector
Old Jul 7, 2016 | 03:57 PM
stegal's Avatar
I changed parts just hoping I would get the right one.
Old Jul 7, 2016 | 03:58 PM
stegal's Avatar
do you mean the one that goes to ignition module
Old Jul 7, 2016 | 05:50 PM
stegal's Avatar
Re: no start
There is power to both conections of the two pin connector with ignition on.
Old Jul 11, 2016 | 04:41 PM
NINÅ's Avatar
Transmission: 765R4
No Sparks Remarks
Reconnect that plug and grab a test light (the type for testing for voltage, not a continuity tester).
Connect one lead to the coil primary
(the ignition module side not the key side) and the other lead to ground.
Crank the engine.
Does the test light FLASH while cranking?
Be aware of the difference of FLASHING verses PULSATING which will be observed when you have the test light connected to the key side.
Happy Racing !
Old Jul 11, 2016 | 05:10 PM
stegal's Avatar
Re: no start
It is the ecm. I got no pulse at the injectors but could prime to start.
2slowfox
Jan 31, 2017 12:25 AM
dcd2236
Jul 7, 2016 10:28 PM
thtanner
Jul 3, 2016 02:12 PM
chriskovach
Jul 2, 2016 01:56 AM
Buddy
Jun 17, 2016 11:44 AM
