Fuel Gauge
Old Aug 1, 2016 | 03:54 PM
stegal's Avatar
Car: 1990 RS, 2002 Chev Silverado
Fuel Gauge
I changed my fuel pump and now gauge won't work.
Took it back out and still can't fix it any ideas. Pump has power.
Old Aug 15, 2016 | 04:35 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Rage
It’s a good idea to test the gage, and faster than replacing the dash or sender.
Here’s how to test the fuel gage.
Remove the sender wire going to the gage.
Tape the bare end of the sender wire and put it aside.
Use a potentiometer with a value of 100Ω or the closest you can find.
Connect one end the potentiometer to the gage from the location you removed the sender.
Connect the wiper of the potentiometer to ground.
Turn the key to RUN.
Slowly adjust the potentiometer from 0Ω to 90Ω.
If the gage is bad it will exhibit the problem you have.
If the gage is good it will display a smooth transition from one end of it’s range to the other.
Therefore the problem is with the sender or wiring going to it.
You can use a loose potentiometer, or you can throw together a quick little panel like this one.
Happy Racing !
Whether The Street Car At A Traffic Light Or The Nitro Funny At The Strip, Yellow Means Floor It !
91banditt2
Aug 11, 2021 10:54 AM
mikey8494
Apr 26, 2016 08:00 PM
racerx520
Apr 13, 2016 09:54 AM
Camarokid01
Aftermarket Product Review
Mar 18, 2001 02:26 PM
