New headlamps wiring question
Old Aug 7, 2016 | 05:56 PM
patricktroyz28's Avatar
Car: 1991 Z-28
Transmission: 4L60
Without having to get a new wiring harness that runs off the battery, Is there a risk of burning up a 91Z wiring harness with H4 bulbs?
If so, is the H4 bulbs and or HID the only one off limits to original factory wiring?
SYLVANIA H4651 SilverStar are direct replacements as I have read in several threads, but draw 55W, the same as a H4 55 watt bulb....what's the difference, outside of a different pin configuration, where you need to switch 2 of the 3 on the H4?
Thanks!
Old Aug 7, 2016 | 11:38 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: New headlamps wiring question
Yes, you need to build or buy and install a heavier wiring harness for H4 lighting
Original wiring and switching won't like it and will range from unsteady lighting to possible melting of wiring. Here's a handy article from the how tos section explaining it pretty well
Well worth doing
OOPS wrong link somehow, here's the right one
https://www.thirdgen.org/headlightupgrade/
Old Aug 8, 2016 | 06:31 PM
Car: 1991 Z-28
Transmission: 4L60
Thanks Henryd3! I have the wiring harness but going to try a few combos to get it to work....have conflicting info!
Bullydawg
Aug 17, 2016 10:07 PM
aaron7
Sep 26, 2004 08:18 PM
IHI
May 25, 2003 08:36 PM
