1988 firebird headlight funkyness
Old Sep 4, 2016 | 12:47 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Hello, I just started up my car and one head light wouldnt go up ? So I flicked the switch a few times and got it moving a little way then giving up. Eventually it went up and I thought great untill I walked around the car ( hood was up) and realised the other side wasnt up, so the problem jumped !? They both went down fine. Im guessing its a central problem with something but where do I start ?
Ant.
Old Sep 4, 2016 | 01:27 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Re: 1988 firebird headlight funkyness
May need to rebuild the motor that raises the light. I had the same issue a couple of years ago. I bought a rebuild kit off eBay.
Old Sep 4, 2016 | 02:52 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Thanks ill look, although im not sure it is because up till now theve both been fast up/down and worked awesome.
Old Sep 4, 2016 | 03:23 PM
Engine: 5.7
Axle/Gears: Stock
yeah so did mine. If you have a test light power them on and unplug the connector to the motor, see if its getting power, if so, its the motor.
Old Sep 6, 2016 | 03:53 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
well, its nice out so i went out to have a look, took 3mins im sure i used to be able to raise the lights manualy but i cant raise either light manually any more like the gearings knackered.
cant believe they both would go at the same time wtf!?!?!
Old Sep 8, 2016 | 12:09 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Unfortunately you waited a bit too long to do the repair. Now a one person job has become a two person job. Have someone push the headlight switch on/off while you shake and bang on the headlight door with your fist. It will eventually come up suddenly. Then you'll be able to do the headlight repair.
I also sell a few kits to repair these headlight motors:
http://www.top-downsolutions.com/Bod...ght-repair-kit
http://www.top-downsolutions.com/Bod...ight-motor-kit
Lon Salgren
Michael Harding
Jan 12, 2019 11:11 PM
thecaminator
Apr 5, 2016 11:53 PM
Polo Z03
Mar 27, 2016 08:17 PM
That Sky Guy
Mar 15, 2016 07:40 AM
dm3k
Mar 12, 2016 08:04 PM
