Gauge cluster
Old Sep 10, 2016 | 11:26 AM
J&k86ta's Avatar
Gauge cluster
I have a 1986 ta everything worked but the odometer I pulled the cluster and put another in it and it didn't work at all so I put mine back in and now the speedo isn't working everything else is but it all worked before
Old Sep 12, 2016 | 04:52 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cluster Buster
Sounds like you inadvertently disconnected something.
See if the VSS signal is still getting to the dash.
Use an audio amplifier to make sure it’s getting a steady signal.
Connect the amp’s input to the
gray wire pin 8 going to the dash at the dash connector on the right as you would a CD player.
If in 8 is not
gray your dash configuration if different but you can find out which wire is coming from the VSS by physical tracing.
Happy Racing !
Nitromethane Smells Sweet Burning, But Please, No Roasting Marshmallows On The Zoomies
makingPAIN
Oct 28, 2017 10:49 AM
Black_Widdow
Sep 19, 2016 12:15 AM
Cody Willey
Sep 10, 2016 05:38 PM
Bobby Suth
Sep 9, 2016 06:46 AM
justininaz
Sep 6, 2016 03:57 PM
