Tachometer wiring with engine swap
Old Sep 12, 2016 | 09:48 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I have yet to get the tach to work at all since the LS engine swap in my '89 Firebird. It would be helpful if somebody could verify I am using the correct connection.
I have Holley HP EFI and have verified with an O-scope that there is a tachometer signal with a square wave at system voltage. I am running that signal through C100 D6 terminal (white wire). And I have verified the wire goes to the BROWN connector Pin 1 at the gauge panel, as shown below. The circuit trace from Pin 1 winds over to a connection at the tachometer with a negative symbol close by.
Is there anything wrong with the connection itself? Am I missing a screw in the empty hole next to the negative symbol? If not, then I suspect the tachometer to need repair.
Old Sep 12, 2016 | 10:11 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Tachometer wiring with engine swap
Well damn, this guy has a screw that I am missing.
http://s35.photobucket.com/user/Cree...e0020.jpg.html
Old Sep 13, 2016 | 06:57 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yep, that was it. Tach works now and it is really accurate too.
Dodgeman79
Sep 16, 2016 10:59 PM
Happy days
Sep 3, 2016 12:21 PM
Jeffpenry
Aug 29, 2016 09:01 PM
Tibo
Aug 26, 2016 09:29 PM
DrRedAxel
Aug 26, 2016 03:27 PM
