Speedo stuck?
Old Dec 30, 2001 | 08:16 PM
25thRS's Avatar
Speedo stuck?
For the past few months, my speedo has refused to move right after starting out. In the beginning, I'd have to drive 1/4 mile or so and it would "pop" up to 15-20 then run normally. Lately, it takes more distance and higher speeds to get it to move - now up to about 5 miles and won't come on until I hit at least 40 or so.
It's a 92, so it has the electronic guages. Is this an electronic problem or are the mechanical parts to blame?
Any suggestions on how to check this out and what to try first?
Old Dec 31, 2001 | 12:28 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Sounds like it is the gauge. If it was the wiring it should work more randomly and not only at certain speeds. You can buy a new speedometer gauge off ebay for pretty cheep.
Old Jan 1, 2002 | 07:35 PM
25thRS's Avatar
Thanks, 89 IROC Z. Any idea if it's repairable? Since you think it's mechanical as opposed to wiring, I'm wondering if a good old fashioned cleaning of the mechanism might help.
I'm a bit leary of a used one, from eBay or the scrap yard plus, being a 92 it has the yellow markings rather than the much more common white. Took me forever to find a yellow cig lighter to fill that hole in my dash.
Thanks again
T
Old Jan 1, 2002 | 08:37 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
It’s been a while since I have taken apart a 90-92 dash. I think you are going to have to replace the gauge. Try making sure all electoral contacts are tight on the gauge and the dash but it sounds like the gauge just needs to be replaced.
Old Jan 10, 2002 | 12:12 PM
Mike91rs's Avatar
I'm having that same problem. Only on my 91 RS, it's not moving for oh I'd say about 20 mins. My engine light lights up too, until the speedo kicks in. Any comments?
Old Nov 18, 2004 | 05:15 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
I realize this is an old post but maby someone can give some more advice. I have the same problem in my 91Z and today when I went for a drive (the first in a while) it never came on and the odometer didn't register any miles eather. Any more oppinions? thanks
Old Nov 18, 2004 | 05:54 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Check out my thread further down the board for a little info:
https://www.thirdgen.org/techbb2/sho...hreadid=267553
Did your SES light (check engine light) come on at all, especially a code 24? Most of the time the problem is just your VSS (vehicle speed sensor), but not always. Do you have access to a scan tool or laptop and ALDL cable? I'm asking because with those you can see if the computer is seeing vehicle speed or not, which will narrow down the problem. If Trickster doesn't post here than just ask him for some info on a code 24 for a 91 Z. Sorry I'm not of more help.
Old Nov 18, 2004 | 06:42 PM
camaro05's Avatar
Car: 91 Z28
Thanks for the info. I have a laptop but no aldl cable. I read the other thread and I have exprienced the same thing. The SES light came one while drving 2 seperate times but hasent been on since. I will jack up the car sometime and check the cable and Iwill post on the other thread if I have any more questions. thanks
Old Nov 18, 2004 | 07:41 PM
Benm109's Avatar
Engine: 305 TBI
When you say "check the cable", do you mean the speedometer cable? Just asking because the '90 and later 3rd gens don't have speedometer cables, they're electronic.
By the way, your 91 Z looks awesome (just saw your CarDomain site)!
Old Nov 18, 2004 | 09:27 PM
camaro05's Avatar
Car: 91 Z28
I meant the speed sensor wiring on the trans. I read in the other post that it can come loose? Thanks for the compliment on the car too.
Old Nov 19, 2004 | 01:12 PM
Benm109's Avatar
Engine: 305 TBI
Oh OK, I understand what your saying now, and yes, the wire can sometimes get loose or come off.
Elephantismo
Feb 13, 2019 12:51 AM
tmellott89
Oct 14, 2015 02:06 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
TrevinE
Sep 14, 2015 03:20 PM
