Vats or not Vats?
Old Jun 13, 2017 | 08:05 AM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
Vats or not Vats?
So every once and a while for the last few days my car wouldn't attempt to crank. A few minutes later it would. I just assumed it was the starter or solenoid since it was old and a cheap lifetime warranty one. I replaced the starter and all the old original battery cables and even had the alternator and battery tested for good measure. Everything seemed great and it started with every test after I finished yesterday. I go out to start it this morning and it's back. No crank. I noticed after the first failed crank attempt if I pull the key out and put it back in the "security" light would come on solid and stay on with every attempt unless I waited a few minutes. I tried my 2nd original key that has low wear and there was no difference. Does this sound like a simple Vats issue that I can bypass? From what I've read there's no other reason the "security" light would come/stay on unless it was Vats. I guess I just expected it to be on on the first attempt as well. Maybe that's just the way it works. Thanks guys.
Old Jun 13, 2017 | 10:02 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Vats or not Vats?
https://www.thirdgen.org/forums/elec...-no-start.html
Old Jun 13, 2017 | 12:57 PM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
Thanks! Just wanted confirmation. I do indeed have code 53 as well.
Old Jun 13, 2017 | 04:57 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If you want to do the resistor thing, here's one of several sources that makes it easy to get the right ones
Amazon Amazon
Old Jun 13, 2017 | 05:02 PM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
Thanks! I'll check my local Radio Shack first. I'm not sure how long I can borrow my in-laws' car while that ships haha.
Old Jun 14, 2017 | 03:15 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Jump the starter enable relay like this.
The relay is removed and you use the two outside slots.
Its in the drivers side kick panel by your left foot.
This is a random photo I found.
Use a heavy gauge wire with spade connectors as shown then rap it with electrical tape to protect it and keep the jumper in.
Quite a lot of voltage going through that wire when you crank the car so be careful.
That will keep the VATS System from disabling the starter.
If its VATS the car will now crank every time but you will not get fuel.
Once you install the resister it should now start.
Old Jun 14, 2017 | 03:31 AM
Engine: TBI,5.0
Here's how you test your key for resistance. Only touch the resister with the tester set on ohms/resistance.
You should be able to take that "value" to Radio Shack and find the resistor or resistors you will need.
Here's where I put my resister.
If you don't solder you can get very small "butt" connectors at Radio Shack also.
There just tiny little metal tubes. No plastic on them like this. = = https://www.radioshack.com/products/...utt-connectors
Old Jun 14, 2017 | 07:46 AM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
Thanks Ron I'll be doing this this weekend. Hopefully my Radio Shack still has a resistor selection!
Old Jun 14, 2017 | 03:54 PM
Engine: Lb9
Transmission: M20
If you want the vats gone for good send me a pm. I can program a prom to eliminate it completely.like Ron pointed out the starter enable relay would need to be bypassed.
Old Jun 14, 2017 | 09:08 PM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
Would the prom replace my ADS Superchip from 1990 something? What's the function of leaving the starter enable relay bypassed once vats is confirmed as the fault? My understanding is that it's just a troubleshooting method to confirm vats is cutting the starter and fuel.
Old Jun 15, 2017 | 06:12 PM
Engine: Lb9
Transmission: M20
The vats also controls the enable relay, a new prom would replays the super chip.
Old Jun 15, 2017 | 07:11 PM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
Oh so the VATS bypass by prom would need the starter enable relay manually bypassed as well?...because it needs to be controlled by VATS and VATS is no longer "there" so it would default to disabled? Why would no manual "fuel relay" (or however VATS cuts fuel) bypass be necessary in that case as well?
So if you bypass by resistor everything stays where it is, you're just always telling VATS the right key is in and there would be no reason to bypass the starter enable relay correct? What would be the benefit of prom/starter relay bypass over resistor only?
Old Jun 15, 2017 | 08:34 PM
Engine: Lb9
Transmission: M20
The resistor just bypasses the lock cylinder reader. The vats kills fuel injector pulse. A prom with vats programmed out the ecm to expect to see a vats signal and will not cut injector pulse. The enable relay doesn't need to be bypassed doing a resister but it's a common failure item.
Old Jun 15, 2017 | 08:36 PM
Engine: Lb9
Transmission: M20
Another option is to feed the ecm a hz signal that it's expecting from the passkey module.
http://m.ebay.com/itm/GM-VATS-or-PAS...%257Ciid%253A8
Old Jun 18, 2017 | 03:31 AM
Engine: TBI,5.0
In the end, after messing with VATS and a few other problems I finally had "Tuned Performance" reprogram my "EPROM" and had a few other items changed and its one of the best things Ive done for my car.
He's a really great guy to work with.
Old Jun 19, 2017 | 10:05 PM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
Just fyi I just patched in the resistor combo that matched my key and that was it! Thanks to all of you for your input.
