Fog light relay
Old Aug 14, 2017 | 10:29 PM
Billy Pruitt's Avatar
Fog light relay
I have a 1992 Firebird does anyone know where the fog light relay is located. I thought I have looked everywhere but obviously not!!
Old Aug 15, 2017 | 12:17 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Fog light relay
I believe it is under the dash. I have a 92 also, I can look in the shop manual for you. There were two or three relays under there, I THINK it is on the side of the fuse block, just clipped on
Old Aug 15, 2017 | 12:30 PM
Re: Fog light relay
Old Aug 15, 2017 | 12:33 PM
Re: Fog light relay
Thanks a lot, never thought about looking there. I have been all around underneath the hood. I will be sure to check that out as soon as I get home!
Old Aug 15, 2017 | 12:39 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Re: Fog light relay
In my 88 GTA the fog light relay was under the hood, on the LH fender rail. It used to stick on and I would have to give the fender a good smack and it would shut off. GM moved it later to the inside of the car.
Old Jan 29, 2018 | 08:42 PM
Sweatlock's Avatar
Re: Fog light relay
BillyPruitt, did you ever find your fog light relay? I have been looking for mine in my '92 Firebird and still can't find it...like yours, my fog lights don't work.
Old Jan 29, 2018 | 09:35 PM
Drew's Avatar
Re: Fog light relay
It's right next to the fuse block/aldl in later thirdgens.
Old Jan 30, 2018 | 05:48 AM
Sweatlock's Avatar
Re: Fog light relay
For some reason I can't find it or the connector - which may or may not be the problem, lol.
Does anyone one have a photo that they can share? This is driving me nuts, kinda like the tonneau cover relay my '92 service manual says is in two different locations and the 'net says is inside the console - on my car it's actually behind the passenger's side dash next to the ECM, lmao.
Old Jan 30, 2018 | 12:13 PM
Drew's Avatar
Re: Fog light relay
I could take a picture. Or you could locate the diagnostic port next to the fuse block, feel behind the diagnostic port for the bundle of wires and follow them back about 6" to a square plug with a blue, green, yellow, and purple wires. You really can't miss it.
