Headlights flicking
Old Mar 26, 2018 | 12:41 AM
Easye89's Avatar
Headlights flicking
I need help with my headlight fusible link. I have a 92 camaro rs and when I have been running with my headlights on for a little bit they start to flicker. Any suggestions on where to start.
Old Mar 26, 2018 | 01:22 AM
Drew's Avatar
Re: Headlights flicking
Sounds like the circuit breaker built into your headlight switch is giving up the ghost. But that's just an educated guess. A fusible link will go up in smoke, and you lose all power. Working for awhile then flickering and going out is a heat issue.
Old Mar 26, 2018 | 02:37 AM
Easye89's Avatar
I be changed that headlight switch 3 times and all did it. But I guarantee it is a heat problem because it last a lot longer if I don't turn my heat on and ride with the windows down(being that it's cold here). Is it possible that it' not grounded correctly or that I have a grommet in the wire.
Old Apr 2, 2018 | 05:13 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Throw Away Those Crazy Non-Incandescent Headlights
Originally Posted by Easye89
and all did it
What did what?
No and no.
If the new breaker is giving the same problem the cause can be non-stock headlights.
Happy Racing !
If We Don’t Get Cawt We Ain’t Cheatin’
Old Apr 2, 2018 | 11:40 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The headlight Ground wires are bolted to the radiator support on each side of the radiator using a 10mm bolt/screw. Loosen them up and re-torque,..... then check operation once again. With any luck you'll maybe spot a weak wire or a little surface rust and can resolve the problem quick and easy !
Old Apr 9, 2018 | 01:28 AM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
had this exact issue and it was the switch overheating, ended up installing 2 relays, one for high and one for low beam, and using the wiring from the switch as the trigger and running a dedicated battery power to the relay. resolved the issue entirely.
akmusclecar
Nov 30, 2008 02:12 PM
devianb
Mar 17, 2004 08:44 PM
F-B0DYCAMAR0_83
Apr 16, 2001 10:16 AM
