CCC Removal/Standard Carb Swap Wiring Help
Car: '86 Z28
Forgive me as I'm a little new to the third gen world. I've found tons of info on TPI to carb swaps, but can't quite find what I'm looking for here.
I'm swapping in a 383 with a standard carb and distributor in my '86 z28 that originally came with a CCC/quadrajetted 305. This will be a stripped down street/strip car - I want to remove everything in the engine bay that isn't essential to controlling the motor (no heat/AC either). Am I good to go by yanking the entire passenger side wiring harness from the ECU? What else can be removed (wiring-wise) here?
Thanks!
Thanks!
Re: CCC Removal/Standard Carb Swap Wiring Help
The wiring harness going into your passanger side fender well into the passager kick panel, remove that and all those wires. Wire your fans up to a toggle switch and your pretty much done. It cleans up the bay alot. Just remember that after removing the ecu go with a standard hei distributor or get a msd box.
And you will have to do something about locking the TCC.
Yeah put it on a toggle switch or dont use the tcc. the is also a write up of tying it into the brake light switch so it disengages when the brakes are hit. If he switching to carb the tcc wont work anyways wothout a tps.
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
I got a vacuum operated lockup switch from Jegs that works pretty well. It disengages when you let off the gas, or you can run it through the brake light circut
