Tech: How to bypass VATS
Old May 10, 2026 | 06:47 PM
  #151
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tech: How to bypass VATS
Where have you followed the path of power starting at the ignition switch ?
Old May 11, 2026 | 07:06 PM
  #152
CaptCutlass's Avatar
Car: 1990 IROC Z-28 Convertible
As stated, I have power to the yellow wire, when in the crank position, that goes to the connection that goes into the relay.
Old May 11, 2026 | 07:07 PM
  #153
Engine: Lb9
Transmission: M20
And nothing on
tje large gauge green ?
Old May 11, 2026 | 07:19 PM
  #154
There is no large green wire in that connection. From my view point Only the large yellow and 1 large yellow/green one, a smaller yellow/green one and a large tarnish wire on the opposite end from the yellow one. Only the yellow was getting power.
Old May 11, 2026 | 07:26 PM
  #155
Engine: Lb9
Transmission: M20
Is there a large gauge purple or any other gauge he similar to the size of the yellow on the outside spot on the relay harness ?
Old May 11, 2026 | 07:28 PM
  #156
I'll get back to you on that when I resume working on it. Maybe tomorrow.
Old May 30, 2026 | 08:21 PM
  #157
JeffR83's Avatar
New 92 Z28 owner,,,,,, I'm trying to bypass VATS via the resistor Method A. On the voltmeter my key reads 68 ohms on the 20K ohm setting. I assumed that meant key #3 (with a 681 range). Am I confused, or should I proceed looking for a 68 ohm resistor. Thanks in advance.
Old May 30, 2026 | 09:10 PM
  #158
Engine: Lb9
Transmission: M20
Does your vom have a lower scale ?
Old Jun 1, 2026 | 07:35 PM
  #159
JeffR83's Avatar
I lowered the scale (2,000?) and got a reading of 689. So #3 it is. Thanks for assist Tuned Performance. Now to find a 680 resistor....
Old Jun 1, 2026 | 08:03 PM
  #160
Engine: Lb9
Transmission: M20
https://ebay.us/m/l3SbPN
Amazon Amazon
might find cheaper just needing the 1
Old Jun 3, 2026 | 04:10 PM
  #161
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
And if you have your dash out for Vintage Air, I can show a pic of the Pass Key module.
Amillionoh7
Jan 27, 2015 07:31 AM
CamaroMike
Aug 24, 2006 12:33 PM
89RsPower!
Feb 10, 2005 11:00 AM
a73camaro
Dec 13, 2001 10:31 AM
